Arduberry work with Braccio motor control board
Would the Arduberry work with the Braccio motor control board?
I have both Pi2 and Pi3’s available. Know about switching off serial and Bluetooth on the Pi3 :slight_smile:
Also have a couple of Pi2’s with BrickPi installed.
Robin
@rpehlm,
Is this the shield that you are talking about : http://www.arduino.org/products/tinkerkit/arduino-tinkerkit-braccio . We have not tried it but it does look like it should work with the Arduberry.
You should be a bit careful about the power supply though. The tech specs say that you need 5V at 5A which is a lot. I am not sure if it is shared with the Arduino, if it is then it would be shared with the Pi too. Servo’s tend to generate a lot of noise in the power channel which could make you Pi run a bit unstably. So this project would be more like, proceed on your own risk.
You should also have a look at the pivotpi here that we sell for the Raspberry Pi: https://www.dexterindustries.com/pivotpi/ which you can use to control the servo motors with the Braccio. Might make it easier for you to control the Arm from Pi itself and we have a library in C and Scratch too.
Hi Karan,
Whoops! Tried replying using my Xojo address :wink:
Yes - that is the one.
BTW, thank you very much for the prompt response. Very unexpected given
the time of year!
Do you have a European distributor (I’m in Germany)?
Robin
Arduberry Appears to be in stock in Generation Robots here.
