Thanks for the quick response! I downloaded your image and everything seems to be working great. Thanks for all your help! May I suggest that you guys put in your arduberry start up guide that you recommend using your own OS with the arduberry.
Thanks again for your help and quick response! I will be buying from you guys again.
I am now getting the same error again. I now get it every time I try to use the Arduino IDE, even when no shield is plugged in. I already tried re flashing the OS image. We even tried replacing the programming chip with a working one from an Arduino we had laying around to no luck.
We get the error on both the Raspberry pi B+ or 2.
We had been running code successfully for two weeks and then during one compile it just stopped. This is pretty upsetting because we have a design day presentation on Friday and now do not have anything working. Any help you could provide would be greatly appreciated.
update: I can successfully upload a sketch after disconnecting the circuit used with the Arduberry.
Example: For the blink sketch, I have to remove either the ground or pin 13 and I’ll be able to upload a new sketch. Keeping both of them plugged in will result in “AVR device not responding” error.
It’ll be annoying to physically unplug and re-plug circuitry for every sketch iteration.
Step 1 tells you to connect the LED to pin 13, which will prevent Step 3 from working.
Took me forever to find out what the problem was (numerous google searches FINALLY landed me here), and I’m a grown man. I feel bad for any kid who would try to stumble through this.
