Connect to Pi
I have the Arduberry 2.0 and Raspberry Pi 2 Model B V1.1. Unsure how to connect the two since the Pi has more pins on the GPIO than fit into the Arduberry. Assuming that some of the Pi pins are not needed to run the Arduberry?
Also, am I powering both via the Pi’s power supply and programming both or just the Arduberry?
Sorry for the very basic questions buy I am just trying to get familiar.
Is the attached photo correct? What next?
Steve
Hi Steve,
Here is a link to the post on how you connect the Arduberry and a Pi B+ or Pi2: http://www.dexterindustries.com/Arduberry/getting-started/raspberry-pi-b-arduberry/. You can power the whole setup directly from the Pi. If you want to use the Arduberry without the Pi, then you can use the DS Jack to power it.
You can have a look at the other documentation on the Arduberry here: http://www.dexterindustries.com/arduberry-tutorials-documentation/.
