SO dex.local didnt work so i Assign Static IP Address i did all of the steps when i ping my static ip address in cmd is says Pinging (ip) with 32 bytes of data:
Reply from (ip): Destination host unreachable.
Ping statistics for (ip):
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
please help
Abodi,
A few questions:
1). What IP address did you give your Pi?
2). How are you powering your Pi?
3). Do you get solid power light and a blinking ACT light?
4). Are you connecting over ethernet?
5). If yes on #4, do you have ethernet lights powered and blinking?
1.i gave it the ip that i got from the Ethernet thing then i changed the 0 to a 1
2. using the cable but i have the battery connected but not on
3.act light is blinking
4.yes
5. yes the Ethernet lights are blinking when plugged into my computer
We have heard from another customer that they needed to add 2 to the IP number (in your case, the last digit would be 182). If you change that, is possible to ping the number 169.254.102.182 ?
So it sounds like everything is working fine, it sounds like your computer is just unable to find the Raspberry Pi. This could be a networking issue (like running a firewall or an antivirus program that’s blocking the networking protocol). One last thing to try is to install the latest image, which has ipv6 enabled. This is 2016.01.05 in our sourceforge library here: https://sourceforge.net/projects/dexterindustriesraspbianflavor/files/?source=navbar
