LED Support in Bloxter
My son is kicking the tires on DexterOS/Bloxter.
The LED Bloxter lessons seem to be available, but when we try to add the LED to the project from the Sensor Control Panel it shows as “soon” (see below)…
Is the LED sensor really not ready to be used yet? In a related question, is there a timeline for when the other sensors will be supported?
-= Brandon.
Hello @brandon-c-aguilar,
The LED sensor is supported through blocks, but not through the control panel. As it’s an output sensor (also known as actuator) it’s not nearly as needed in the control panel as the other sensors. You set the LED to 50, and you see it go to 50%.
So if you use the LED based blocks you’ll be fine.
