Multiple RPISER devices
I have two Grove devices I want to connect to the RPISER port, the Grove CO2 sensor and the Grove GPS sensor. Can I simply user a grove splitter cable to connect them both to the same port?
Hi @raymond.romoth,
I’m afraid you can’t do this since these 2 devices start broadcasting on the serial line at the same time - and there’s no synchronization happening on the RPISER line.
A workaround would be to use a digital selector. The idea is to connect the TX lines of these 2 sensors to a digital selector.
The digital selector is supposed to have an output that lets the signal of one of the two inputs pass depending on a selector input called X.
You can google "1 bit digital selector" and take a look at the images you find - they’re descriptive.
Thanks for the tip. I’ll have a look around and see what I can find. If I can’t get the digital selector to work I might see if I can find a digital CO2 sensor. Any suggestions?
Thanks again
Hi @raymond.romoth,
The following sensor could be a good alternative. It’s from Sparkfun:
I encourage you to read more about it. You can use it along with a GrovePi just fine.
Also, you can connect the sensor via the GPIO ports of the GrovePi.
As for soldering a Grove connector on the Sparkfun module instead, that’s going to be a bit tricky, but it could work eventually.
Cool. Thanks for finding an alternative sensor. I’ll definitely check it
out if I can’t get the digital selector thing working.
Ray
