No Analog or Digital Sensors work!
My school recently purchased a classroom kit of grove pi kits for my programming class. I have two kits of my own. On my kits all the sample codes with every sensor in the kits works just fine. However, on the first of the grovepi kits we ordered none of the analog or digital sensors seems to work. I am using scratch and I have also tried using python directly with no luck. I don’t get an error returned in the code during runtime and it seems like everything should work but it doesn’t. I have tried swapping the raspberry pi out with same end results. Also I have swapped the SD card to one of my working devices as to rule out a software issue and the sensors performed as expected on that one. Is it possible that I could have a faulty device? Only the I2C devices like the LCD display work and NOTHING else. I have spent the better part of the day and only conclusion I can come up with is a bad device. We purchased a class set and this is just the first one from the set. I hope this does not set the trend for the other devices when I assemble them for tomorrow.
Attached is the diagnostic log that I ran using the troubleshooting program on the desktop.
Check space left
/dev/root 3.6G 2.7G 640M 82% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.2M 425M 2% /run
/dev/mmcblk0p1 63M 21M 43M 33% /boot
tmpfs 87M 0 87M 0% /run/user/1000
Check for dependencies
arduino 2:1.6.0 install ok installed
wiringPi Not Found (ERR)
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
  • Device tree is enabled.
  • This Raspberry Pi supports user-level GPIO access.
    -> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 005: ID 045e:00cb Microsoft Corp. Basic Optical Mouse v2.0
Bus 001 Device 004: ID 045e:0752 Microsoft Corp. Wired Keyboard 400
|__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 5: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
V 7.0
This version of Raspbian was modified by Dexter Industries on the Wheezy Raspbian Build.
This version was updated on 2016.10.05
Hostname
DexT1
Checking for Atmega chip
     Using Port                    : unknown
     Using Programmer              : gpio
     AVR Part                      : ATMEGA328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : GPIO
     Description     : Use sysfs interface to bitbang GPIO lines
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version
File “/home/pi/Desktop/GrovePi/Software/Python/grove_firmware_version_check.py”, line 40, in
print(“GrovePi has firmware version: %s” %grovepi.version())
File “/home/pi/Desktop/GrovePi/Software/Python/grovepi.py”, line 265, in version
return “%s.%s.%s” % (number[1], number[2], number[3])
TypeError: ‘int’ object has no attribute ‘getitem
UPDATE
When I got to my class this morning I took out one of the grove PIs from another package and hooked it up to the raspberry pi that I had originally connected. I ran the same programs that I ran before and it worked like a charm. I then swapped the one that I suspect to be defective and guess what!! It still did not work.
SO question to the community is this then. How do I go about getting an exchange on behalf of my school?
You’re grovepi could be broken but it may not. Have you tried updating the firmware? It is easy and shouldn’t longer at all. Here’s the instructions:
https://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/updating-firmware/
If you bought it from here it should have a 30 day return. At least my brickpi did.
If that doesn’t work you could contact Dexter Industries through the contact page or pm @JohnC , founder of Dexter Industries. I’m not sure which contact forum in the contact page to use though.
THANK YOU THANK YOU THANK YOU!!! I assumed that since the others worked that the firmware version were all the same. Guess not. I followed the directions on the page that you provided me and they worked perfectly. Now all the ports work and I have a full classroom set of 7 grovepi start kits that are fully functional!! Thank you so much for your help!
No to get to designing my curriculum for the following school year!
No problem. Glad its working! Hope your class has fun! :smile:
