NodeJs Samples with LCD screen
Hello
I am having hard time trying to find nodejs samples with the groovepi and pi 3.
I want to do a simple hello world, I found a groovepi sample with intel edison but obviously that didnt work.
Doing a little of research, I found johny five library but that its only for arduino, but they are supposed to have plugins for other boards, like raspberry, so installed rasp-io, johnny five and tried to run this sample
var raspi = require(‘raspi-io’);
var five = require(‘johnny-five’);
var board = new five.Board({
io: new raspi()
board.on(‘ready’, function() {
var lcd = new five.LCD({
controller: “JHD1313M1”
lcd.bgColor(r, g, b).cursor(0, 0).print(f);
I get this error:
pi@raspberrypi:~/share/Sample2 $ node index.js
modprobe: ERROR: …/libkmod/libkmod.c:557 kmod_search_moddep() could not open moddep file '/lib/modules/4.4.26-v7+/modules.dep.bin’
child_process.js:531
throw err;
Error: Command failed: modprobe i2c-dev
modprobe: ERROR: …/libkmod/libkmod.c:557 kmod_search_moddep() could not open moddep file ‘/lib/modules/4.4.26-v7+/modules.dep.bin’
at checkExecSyncError (child_process.js:488:13)
at execSync (child_process.js:528:13)
at new I2C (/home/pi/share/Sample2/node_modules/raspi-i2c/lib/index.js:120:33)
at new Raspi (/home/pi/share/Sample2/node_modules/raspi-io/lib/index.js:161:14)
at Object.<anonymous> (/home/pi/share/Sample2/index.js:5:7)
at Module._compile (module.js:571:32)
at Object.Module._extensions..js (module.js:580:10)
at Module.load (module.js:488:32)
at tryModuleLoad (module.js:447:12)
at Function.Module._load (module.js:439:3)
I want to do a simple hello world on the LCD display I got in they key
Sorry for the late reply. This section on github should have the examples you need.
Also maybe read the readme. It tells how to install the nodejs stuff.
