Problem with serial port on Rpi3
Hello. my first port here…
I just installed my Arduberry on a Rpi3
! have a simple script for monitor 2 sensors but i cannot get it to work.
The Arduino IDE shows only serial port ttySO, but 1 read everywhere i must be on, ttyAMA0
I found a python script to test the serial port here:
http://www.instructables.com/id/Read-and-write-from-serial-port-with-Raspberry-Pi/
But that shows only empty screens.
How can i get the serial port working?
Sorry for the followup post, but i can not edit my post.
i found http://raspberrypi.stackexchange.com/questions/935/how-do-i-get-the-data-from-the-serial-port
import serial
serialport = serial.Serial("/dev/ttyS0", 9600, timeout=0.5)
serialport.write("What you want to send")
response = serialport.readlines(None)
print response
But that show a empty screen to…
Hey nono123,
Are you using the Dexter Industries Raspbian for Robots image/SD card or are you using a normal Jessie. Can you post a screenshot of what you are getting.
-karan
Thamks for your reply, but it is working now.
Strange thing was only why it was on ttySO
Glad to hear that it works for you.
We have updated the image too. So it should work now. We have added a symbolic link between ttyAMA0 and ttyS0, and for some reason Arduino IDE just uses ttyS0.
