[SOLVED] About motionEye on GoPiGo
bb49bac34ac0d83686a06e0417fea0dd
Now I am construsting motionEye application on my GoPiGo cas I must create multi cameras system.But Why I cannot access to USB camera that connects to my GoPiGo via USB? And What is my official gopigo camera address port? I think my camera’s port is 8080…Please show me best way to multi camera system on GoPiGo about this problem? I am afraid but In add LAN networking camera available on this system?
Hi @rikemumu55,
The reason why you get Failed to connect to 192.168.1.12 port 8080: Connection refused is because there’s no server running at that address.
In order to be able to video stream, you need a server to bind to a certain IP address and port.
That entirely depends on what setup you have there.
I haven’t worked with motionEye, but judging from the message you got on your interface, you need to setup a so-called Remote motionEye client.
That client will then have to connect to the motionEye server by using the given interface.
Hope this helps you a little bit!
Thx for your reply! I think official GoPiGo default camera module is used in browser streaming robot control system. So I should use simple mjpeg camera I think.This means I MUST buy more better usb camera that support networking camera?This message up to me.Would you follow me more? I am afraid my poor engrish skill…
5f3ebeba7284ba8230bdbed25f2416cf1e5a3dac0d69e301985c2583006688cf
I solved this problem on my own business! Thx you for your support.45f80b1c56e94c92095ce0a5cd2f7054
So should be close!!!
This topic was automatically closed after 22 hours. New replies are no longer allowed.
