[SOLVED] TypeError: 'int' object has no attribute '__getitem__'
I am evaluating the use of the GrovePi for a robotics application, but can’t limit myself to the robotics image. I started with a stock, fully updated and upgraded PIXEL image.
I successfully followed the instructions at
https://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/setting-software/
However, when I run sudo ./all_tests.sh I get an error. The log.txt is pasted below. How do I fix the error?
Check space left
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       5.9G  4.2G  1.5G  74% /
devtmpfs        458M     0  458M   0% /dev
tmpfs           462M  253M  210M  55% /dev/shm
tmpfs           462M  6.3M  456M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           462M     0  462M   0% /sys/fs/cgroup
/dev/mmcblk0p6   66M   21M   45M  32% /boot
tmpfs            93M     0   93M   0% /run/user/1000
/dev/mmcblk0p5   30M  398K   28M   2% /media/pi/SETTINGS
Check for dependencies
git 1:2.1.4-2.1+deb8u3 install ok installed
libi2c-dev  unknown ok not-installed
dpkg-query: no packages found matching arduino
dpkg-query: no packages found matching minicom
wiringPi Not Found (ERR)
wiringPi Found
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Copyright (c) 2012-2015 Gordon Henderson
Raspberry Pi Details:
  Type: Pi 3, Revision: 02, Memory: 1024MB, Maker: Embest
  * Device tree is enabled.
  *--> Raspberry Pi 3 Model B Rev 1.2
  * This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
        |__ Port 4: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 4: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 4: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
Raspbian for Robots Version
Hostname
raspberrypi
Checking for Atmega chip
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         Using Port                    : unknown
         Using Programmer              : gpio
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : GPIO
         Description     : Use sysfs interface to bitbang GPIO lines
avrdude: safemode: hfuse reads as DE
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00:          -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
  File "/home/pi/Desktop/GrovePi/Software/Python/grove_firmware_version_check.py", line 40, in <module>
    print("GrovePi has firmware version: %s" %grovepi.version())
  File "/home/pi/Desktop/GrovePi/Software/Python/grovepi.py", line 265, in version
    return "%s.%s.%s" % (number[1], number[2], number[3])
Hi @mikeseiler,
I think this is related to an issue we have been having for a week or so already.
There’s a temporary issue with the Raspberry Pi's kernel.
We have filed a bug report and we’re waiting for an answer.
In the mean time, we can downgrade to the previous version we have been using so far (which works).
In your Raspberry Pi, please open up a terminal and enter the following command:
sudo rpi-update 52241088c1da59a359110d39c1875cda56496764
I would highly suggest to use copy-paste here, as typos can easily happen with this long command.
This command will downgrade you’re Raspberry Pi's kernel to version 4.4.50 - v7+.
Please, try it out and let us know if it solves your issue.
Awesome. Yes. that fixes it. Case closed.
Now, let me generalize a bit. Does the fact that we are tied to a specific kernel rev mean that the GrovePi is tied to the Raspberry Pi?
Note that there are other SBCs that have the Raspberry Pi GPIO header such as the Odroid C2 or the Intel based UP board. Both will run versions of Ubuntu, which is a different branch of *nix than the Debian Jessie running on the Raspberry Pi.
How difficult might it be to get the GrovePi working on the Odroid C2 or the UP board?
@mikeseiler really glad to hear it works! Phew! Still talking to folks about what changed about the kernel, but hopefully we can keep it a little more updated.
Our software is only really written for the Pi. However, it can be very easily ported to another system like Odroid or even the CHIP (and other languages too). The key is just figuring out the smbus/i2c modules you’re going to use and making sure you have a way to talk to them in python. I think for many of he boards they will port easily if they’re Debian based.
