404 Error on dex.local
r4r
#1
So at home I connected the grove pi to my network and was able to connect with the IP address (didn’t have the cable for the ethernet/usb for my powerbook). All good.
Now, at work just directly connecting via ethernet cable and I get a 404 error.
Apache/2.4.235 (Rasbian) Server at dex.local Port 80.
Terminal ssh login works, but get 404 with IP address too.
#2
Hi @sbraithwaite,
One question:
  1. How did you get the Raspberry Pi to connect to your laptop? Was it with Bonjour or did you share the WiFi internet connection with the Ethernet port?
If you’re using Windows, you might have gotten into a bug of it (Windows) - I see bugs with Windows quite frequently and this would be just another case. For this matter, I’d recommend you restart the laptop as well as the Raspberry Pi (just in case).
Please let me know if that solves the issue.
