Still no luck … here is the output from the firmware_update.sh
pi@raspberrypi ~/Desktop/GoPiGo/Firmware $ sudo ./firmware_update.sh
ATTENTION! Important!
BEFORE PROGRAMMING THE GOPIGO FIRMWARE, DISCONNECT THE MOTORS.
Please confirm that you’ve disconnected the motors.
Have you disconnected the motors before programming the firmware? (y/n)
y
Updating the GoPiGo firmware
Thu Sep 17 22:08:17 UTC 2015
Reading | ################################################## | 100% 0.01s
avrdude: reading input file "0x7F"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0x7F:
avrdude: load data lfuse data from input file 0x7F:
avrdude: input file 0x7F contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: verifying …
avrdude: 1 bytes of lfuse verified
avrdude: safemode: Fuses OK
avrdude done. Thank you.
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "fw_ver_13.cpp.hex"
avrdude: input file fw_ver_13.cpp.hex auto detected as Intel Hex
avrdude: writing flash (10748 bytes):
Writing | ################################################## | 100% 10.66s
avrdude: 10748 bytes of flash written
avrdude: verifying flash memory against fw_ver_13.cpp.hex:
avrdude: load data flash data from input file fw_ver_13.cpp.hex:
avrdude: input file fw_ver_13.cpp.hex contains 10748 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 9.10s
avrdude: 10748 bytes of flash verified
Here is the output from the voltage test …
pi@raspberrypi ~/Desktop/GoPiGo/Software/Python $ sudo python basic_test_all.py
Cmd: v
0.0 V
and finally
sudo i2cdetect -y 1
00: 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
