Distance sensor says Value: Distance sensor: error unknown
I have the same problem with the distance sensor. He went once short then failed.
I leave the two entries here to the same topic. The update of the operating system did not help.
I hope there is a quick solution
Thank you Peter from germany
A fix is coming in a couple of hours. It’s going through tests to confirm nothing else breaks.
The fix is in
You can run an update on your SD card by following the steps on this update page
Thank you for your patience on this issue.
