Distance sensor works with Python, not with Bloxter
My distance sensor (gopigo3, dexteros 2.4.0) works fine when I code it in Python but not in Bloxter. In Bloxter, the sensor control panel says “Value: Distance Sensor: error unknown” for both I2C-1 and I2C-2.
If I try to use the distance sensor in a bloxter program, running the code gives me “init got an unexpected keyword argument ‘port’. Done”
What can I try?
Hi @kl1
I can reproduce the issue and I’m on it . Expect a fix soon!
The fix is in
You can run an update on your SD card by following the steps on this update page
Thank you for your patience on this issue.
