import grovepi
import math
import time
import datetime
import atexit
# Temperature and Humidity Sensor Pro
def getTemp():
DHT_Sensor_Port = 4 # Sensor connected to digital port D4
# Temperature and Humidity Sensor Type
# Grove Base Kit comes with the blue sensor while we use a white pro sensor.
blue = 0 # The Blue colored sensor. DHT11
white = 1 # The White colored Pro sensor. DHT22 (High-precision)
[temp,humidity] = grovepi.dht(DHT_Sensor_Port,white)
return temp, humidity
# Water Sensor
def getWater():
Water_Sensor_Port = 3 # Sensor connected to digital port D3
grovepi.pinMode(Water_Sensor_Port,"INPUT")
waterReading = grovepi.digitalRead(Water_Sensor_Port)
return waterReading
# Air Quality Sensor v1.3
def getAirQuality():
Air_Sensor_Port = 0 # Sensor connected to analog port A0
grovepi.pinMode(Air_Sensor_Port,"INPUT")
airReading = grovepi.analogRead(Air_Sensor_Port)
return airReading
# Gas Sensor MQ2 - Combustible Gas, Smoke
def getMQ2():
MQ2_Sensor_Port = 1 # Sensor connected to analog port A1
grovepi.pinMode(MQ2_Sensor_Port,"INPUT")
gasMQ2Reading = grovepi.analogRead(MQ2_Sensor_Port)
# Calculate gas density - large value means more dense gas
densityMQ2 = (float)(gasMQ2Reading / 1024)
return gasMQ2Reading, densityMQ2
# Gas Sensor MQ9 - Carbon Monoxide, Coal Gas, Liquefied Gas
def getMQ9():
MQ9_Sensor_Port = 2 # Sensor connected to analog port A2
grovepi.pinMode(MQ9_Sensor_Port,"INPUT")
gasMQ9Reading = grovepi.analogRead(MQ9_Sensor_Port)
densityMQ9 = (float)(gasMQ9Reading / 1024)
return gasMQ9Reading, densityMQ9
# Dust Sensor
def getDust():
#Dust sensor connected to digital port D2 - the only port it will work with
atexit.register(grovepi.dust_sensor_dis)
grovepi.dust_sensor_en()
# The dust sensor takes 30 seconds to update the new values
# the fist byte is 1 for a new value and 0 for old values
# second byte is the concentration in pcs/0.01cf
[new_val,lowpulseoccupancy] = grovepi.dustSensorRead()
return new_val, lowpulseoccupancy
#Read above sensors in loop
print ("----------------------")
dateString = '%d/%m/%Y %H:%M:%S'
print datetime.datetime.now().strftime(dateString)
#Temperature & Humidity
[temp,humidity] = getTemp();
if math.isnan(temp) == False and math.isnan(humidity) == False:
print("Temperature = %.02fc Humidity = %.02f%%"%(temp, humidity))
#Water
water = getWater();
#print "Water Detected? = ", water
if water == 0:
print ("Water Sensor Dry")
elif water == 1:
print ("Water Detected")
else:
print ("Check Water Sensor")
#Air Quality
air = getAirQuality();
if air > 700:
print ("High pollution")
elif air > 300:
print ("Low pollution")
else:
print ("Air is fresh")
print "Air Quality = ", air
#MQ2 - Combustible Gas, Smoke
[gasMQ2Reading,densityMQ2] = getMQ2();
print("MQ2 Reading = %.02f MQ2 Density = %.02f%%"%(gasMQ2Reading, densityMQ2))
#MQ9 - Carbon Monoxide, Coal Gas, Liquefied Gas
[gasMQ9Reading,densityMQ9] = getMQ9();
print("MQ9 Reading = %.02f MQ9 Density = %.02f%%"%(gasMQ9Reading, densityMQ9))
#Dust
[new_val,lowpulseoccupancy] = getDust();
if new_val:
print(lowpulseoccupancy)
#Time between sensor readings (seconds)
time.sleep(10)
We have a PR waiting on this issue.
It may fix what you’re encountering.
I’ll be back with an answer as soon as I get on it.
Hi everyone,
It seems that this issue still isn’t resolved with firmware version 1.2.7. Can anyone give an update on this?
Hi @d_cyphert,
Just saw the PR is still open. We’ll try the following days to approve it and hence bump up the version number.
Though, I have to mention, I never personally had an issue with this sensor - so I never encountered the issue described above.
