[SOLVED] GoPiGo3 will not powerup
Hi Team
I have assembled my robot and got this error message when I attempted to flash the board. Any ideas welcome.
(https://docs.google.com/document/d/10ffiHDnmeH1_TD5y91EAJOsmYjlTmWSikfUlAAxTwIE/edit?usp=sharing)
Which version of Raspberry Pi hardware are you using? Flashing the firmware requires RPi 2 or higher (B+ and earlier will fail).
Which Raspberry Pi OS are you using?
Hi Matt
Im using a Pi3 and I have installed the Raspbian for robots.
I can connect with the Pi3 but not the gopigo3. I had it running at first then decided to do an update which resulted board no longer working.
Its 2:30am NZ time so may be a delay in me getting back to you. Just super keen to get robot running.
18%20AM
56%20AM
Hello @dunnr ,
I am going over some unresolved threads and I came upon yours. Did you ever get it to work?
If not, we have a fix in by now. You can do a DI Update, followed by “Update Robot”.
Thanks Cleo all sorted.
Thanks for following up.
This topic was automatically closed after 4 days. New replies are no longer allowed.
