Grove - PH Sensor Kit (E-201C-Blue) Raspberry pi Zero
@jimrh my summary:
Equipment used:
  • Blue seeed probe which comes with grove interface board and cable
  • Pizero (fully updated raspberry pi O/S)
  • Grove base HAT for pizero
Build history:
  • Blue seeed probe arrived, no code available for pi zero despite saying on the site it is compatible.
  • Bought an arduino and used the available seeed code. Results totally innaccurate in the reference solution.
  • Bought a grove base hat, installed it using the following command and have accurate results on the reference solution:
curl -sL https://github.com/Seeed-Studio/grove.py/raw/master/install.sh | sudo bash -s -
Copied and pasted the code below into a python script but needed to add the utf encoding at the top as the file format wasnt compatible when pasted from my browser:
# -*- coding: utf-8 -*-
import math
import sys
import time
from grove.adc import ADC
# CONSTANTS
Vref = 4.95   # volts
Vcal_mv = 646  # milli-volts (using raw value 535 * 4.95/4096 * 1000)
#Vcal_mv = 2588  # milli-volts (using raw value 535 * 4.95/1023 * 1000)  note 10-bit A2D
mv_per_ph = 59.6
ph_per_mv = 1.0 / mv_per_ph
class GrovePH:
    def __init__(self, channel):
        self.channel = channel
        self.adc = ADC()
    @property
    def PH(self):
        value = self.adc.read(self.channel)
        if value != 0:
            voltage_mv = value * Vref / 4096.0 * 1000
            #voltage_mv = value * Vref / 1023.0 * 1000
            PHValue = 7 - ((voltage_mv - Vcal_mv) * ph_per_mv)
            return PHValue
        else:
            return 0
def main():
    #if len(sys.argv) < 2:
    #    print(ā€˜Usage: {} adc_channel’.format(sys.argv[0]))
    #    sys.exit(1)
    #sensor = GrovePH(int(sys.argv[1]))
    sensor = GrovePH(0)
    print('Detecting PH...')
        try:
            print('PH Value: {:2.1f}'.format(sensor.PH))
            time.sleep(1)
        except KeyboardInterrupt:
            print("\nExiting...")
            sys.exit(0)
if __name__ == '__main__':
    main()
TODO:
  1. Test in multiple solutions for accuracy
  2. Find out how to code the built in temp sensor (if indeed there is one)
  3. Maybe add a noise isolator if 1) doesnt work when I test it in my tank (no idea how successful this will be)
  4. Integrate the code into a bash script which will:
  • Turn on my CO2 supply at a specified time via a wifi sonoff or similar before so I dont have to integrate with 240v supply or I may get a separate DC power supply and use a relay hat on the PI to control it.
  • Detect the PH, when it reaches ~ph 6, switch off the power on my co2 solenoid.
  • Send all the debug and results via pushover to my phone.
For anyone trying to follow this thread and get a pH board working with a Raspberry Pi…
Below describes one solution to get a pH probe working with the Raspberry Pi.
Equipment used:
Raspberry Pi Zero
Anyleaf Board and pH probe
Code:
https://pypi.org/project/anyleaf/
Parting Notes:
The AnyLeaf board has its own set of challenges. First and foremost, the Raspberry Pi 3B is a poor choice for any of the pH probes I have tried. I could not get any of them to work with the 3B and the dev recommended to try a zero or a 4. If you have any issues with values that don’t make sense, get a new probe. Your pH values should not bounce around wildly. The calibration routine built into the example script is a bit cumbersome but it works. If you get any readings that seem off par, recalibrate.
I have noticed that the probe stays in calibration until you add any new peripheral device to the pi via GPIO. I have had my settings persist after reboot but be prepared to calibrate it often. If the probe is in your tank 24 / 7, I don’t think you will need to recalibrate as often. I will find out here in a few weeks how well calibration stays.
I really appreciate everyone in this forum. Thank you for the support!
After some more testing my final verdict for the blue seeed pH-electrode: don“t buy it. Not surprisingly, I know. I tested with different solutions of known pH (4, 7, 9) and checked the raw values coming from the board. While there is a clear difference between the values of pH 4 and 7 there is nearly no difference between 7 and 9. So all calibration attempts are useless.
Just out of curiosity I will order a pH-electrode with a BNC-connector for aquaristics and plug it into my setup. I`ll set myself a cost limit of 50 Euro and see what I can get for the money. Will post the findings here, but it might take some time.
OK, after all that time the aquapi has finally reached its destination.
I am using a pH-electrode from an aquaristics supply vendor at the moment, the rest of the setup is unchanged. However, I wasn“t able to calibrate the new electrode. I had the same behaviour as with the seeed electrode, at pH 7 the raw value was more or less constant when moving into higher pH-ranges. Maybe it“s a problem with the interface board, I don“t know and leave it at that. So right now the pH-values are more of a qualitative nature, one could see sudden drops in value but the explicit value measured ist more or less a guideline.
Another interesting fact: as soon as the lights go down in the aquarium the pH-value goes up significantly to stay at that higher level until the lights go on again. This fits nicely with something stated way above this post: small currents leaking from the devices in the aquarium into the water can have a huge effect on measurements. I will code some time-based correction factor into my script, as I know exactly when the lights are on or off.
Thats it from me, I learned a lot with this project and really appreciate the friendly discussion and support here.
