GrovePi+ and Simple 433 MHz RF link kit
Hey Frederic,
So it it finally working for you with the Raspberry Pi?
Hi Karan,
I’ve implemented support for the transmitter module. It does work, but it’s plagued by i2c communication errors between the Raspberry Pi and the GrovePi+ firmware - much, much more than what I am used to.
Unfortunately, I have to issue several i2c commands in a row to get past the 4-bytes command limitation, which makes my code quite brittle whenever these communication errors occur (1 every 4-5 frames).
I will make a pull request soon, so that you can give a look if you have time, and tell me if you see something I should do differently.
Frederic
