[SOLVED] GrovePi Test Log - Pi not working
Just got Raspberry Pi and Grove Pi, connected together and tried to get sensors to work (gas, sonic, temp, motion) but no joy. Here is GrovePi test results log, any ideas on why no luck?
Check space left
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        14G  3.2G  9.2G  26% /
devtmpfs        460M     0  460M   0% /dev
tmpfs           464M   22M  443M   5% /dev/shm
tmpfs           464M  6.3M  458M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           464M     0  464M   0% /sys/fs/cgroup
/dev/mmcblk0p6   68M   23M   46M  33% /boot
tmpfs            93M     0   93M   0% /run/user/1000
/dev/mmcblk0p5   30M  1.6M   27M   6% /media/pi/SETTINGS
Check for dependencies
python 2.7.13-2 install ok installed
python-pip 9.0.1-2+rpt2 install ok installed
git 1:2.11.0-3+deb9u4 install ok installed
libi2c-dev 3.1.2-3 install ok installed
python-serial 3.2.1-1 install ok installed
python-rpi.gpio 0.6.5~stretch-1 install ok installed
i2c-tools 3.1.2-3 install ok installed
python-smbus 3.1.2-3 install ok installed
dpkg-query: no packages found matching arduino
dpkg-query: no packages found matching minicom
dpkg-query: no packages found matching scratch
find: ‘/run/user/1000/gvfs’: Permission denied
find: ‘/proc/711/task/711/net’: Invalid argument
find: ‘/proc/711/net’: Invalid argument
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.46
Copyright (c) 2012-2018 Gordon Henderson
Raspberry Pi Details:
  Type: Pi 3+, Revision: 03, Memory: 1024MB, Maker: Sony
  * Device tree is enabled.
  *--> Raspberry Pi 3 Model B Plus Rev 1.3
  * This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
            |__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
            |__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
            |__ Port 3: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
            |__ Port 3: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
Raspbian for Robots Version
Hostname
raspberrypi
Checking for Atmega chip
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         Using Port                    : unknown
         Using Programmer              : gpio
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : GPIO
         Description     : Use sysfs interface to bitbang GPIO lines
avrdude: safemode: hfuse reads as DE
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00:          -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
  File "/home/pi/Dexter/GrovePi/Software/Python/grove_firmware_version_check.py", line 40, in <module>
    print("GrovePi has firmware version: %s" %grovepi.version())
  File "/home/pi/Dexter/GrovePi/Software/Python/grovepi.py", line 266, in version
    return "%s.%s.%s" % (number[1], number[2], number[3])
TypeError: 'int' object has no attribute '__getitem__'
Yeah, so I think you have an outdated version of the firmware on the GrovePi. Do an update by running the script that’s in the Firmware directory of the GrovePi repo and then see if the test log changes its output.
This is the script you have to run: https://github.com/DexterInd/GrovePi/blob/master/Firmware/firmware_update.sh
Also, be sure you have got the latest version of the GrovePi’s libraries installed.
Robert,
Thanks, I updated the firmware and most of the sensors I have are now working!
