I’m getting the error below when running a script to get some temperature reads:
I’m using Raspbian OS Buster and Python 3.7.3, full error message is below, any thoughts?
pi@gopigo:~/Desktop/Projects/GoPiGo $ sudo python3 temp_data.py
File “temp_data.py”, line 3, in
from di_sensors import easy_temp_hum_press
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 668, in _load_unlocked
File “”, line 638, in _load_backward_compatible
File “/usr/local/lib/python3.7/dist-packages/DI_Sensors-1.0.0-py3.7.egg/di_sensors/easy_temp_hum_press.py”, line 19, in
File “/usr/local/lib/python3.7/dist-packages/DI_Sensors-1.0.0-py3.7.egg/di_sensors/easy_mutex.py”, line 5, in
AttributeError: module ‘I2C_mutex’ has no attribute ‘Mutex’
