V1 Result: Your GoPiGo3 on ROS2 in 10 minutes - not…
network-config had my SSID and a hash (didn’t confirm it was correct, but I am sure the password was correct in the Rasp. Pi config tool). But the robot never showed up on my router dashboard.
I’m going to have to attach a monitor and keyboard to troubleshoot. I’ve got houseguests coming in today for the weekend, so likely next week before I can touch this again.
/K
10/22: Where I am in testing: “Seeing the bleeding edge”
My ROSbot Dave was (and is still) fully working on ROS2 Foxy/Ubuntu 20.04 Focal.
ROS2 Foxy is supported only until November of 2023, (Focal till 2025).
Thus for my “ROS2 on GoPiGo3 Image”, I chose the latest “long term support” release
  • ROS2 Humble Hawksbill (support until 2027)
  • Ubuntu 22.04 Jammy Jellyfish (support until 2027)
    (22.04 is the “Tier 1” - “We Test ROS2 Humble On” platform)
Of course the continually progressing ROS2 and Ubuntu are built upon a million moving parts such as languages, compilers, and coding conventions.
So keeping a robot afloat on this fast moving deep river can be a challenge.
Status:
  • All runable nodes throw “rcl_shutdown already called” error when terminated with no ill effect
  • ros2_gopigo3_node: appears to be fully working
  • imu_sensor_node: appears to be fully working
  • ultrasonic_ranger_node: appears to be fully working
  • Distance_sensor_node: appears fully working
  • gopigo_teleop_node: appears fully working
  • ydlidar_ros2_driver: COMPILE ERROR!
/home/ubuntu/ydlidar_ros2_ws/src/ydlidar_ros2_driver/src/ydlidar_ros2_driver_node.cpp:44:26: error: no matching function for call to ‘rclcpp::Node::declare_parameter(const char [5])’
   44 |   node->declare_parameter("port");
/opt/ros/humble/include/rclcpp/rclcpp/node.hpp:421:3: note:   template argument deduction/substitution failed:
/home/ubuntu/ydlidar_ros2_driver/src/ydlidar_ros2_driver_node.cpp:44:26: note:   candidate expects 4 arguments, 1 provided
It appears the YDLIDAR folk have not revisited their ROS2 driver since getting it to work on Foxy.
We have to solve configuring the networking for this to be useful.
Status Update: (snes wireless gamepad node working)
  • ydlidar_ros2_driver: appears fully working
  • teleop_twist_joy with snes.config.yaml working
  • added a million example ROS2 command scripts:
    • view data topics
    • publish center servo command
  • Added some non-ROS GoPiGo programs to help
    • determine correct wheel-diameter and wheel-base-width
    • write the values to the /home/pi/Dexter/gpg3_config.json file
  • Uses 600MB (1.2GB free of 1.8GB total)
  • Uses 25% - 32% of the Pi4B processor
  • Processor temp: 59degC (That’s real good considering the tiny heatsink - “20degC headroom”)
  • 7W (0.74A at 9.4v) Total Load On Battery
This brings ROS2HH
  • “ROS2 Humble Hawksbill for GoPiGo3 on Ubuntu 22.04 Jammy Jellyfish”
to the equivalent of ROSbot Dave which was
  • “ROS2 Foxy for GoPiGo3 on Ubuntu 20.4 Focal”
Except I have not figured out how to get my old ROS2 Foxy Desktop virtual machine to hear the ROS2HH topics so that I can run rviz2 and see what ROS2HH is seeing.
Would like to deliver ROS2HH with “Drive me around so I can build a map of this room”
So…
  • Installing ros-humble-slam-toolbox (package is 918MB - Wow!)
  • Looking for videos / tutorials on how to configure to build a map from scratch using:
    • ROS2 slam-toolbox, the YDLidar X4, (my odom is only encoders at this point…no fusion w/IMU)
Usually the slam-toolbox, mapping and localization are executed off-board, so this may be real wishful thinking on my part.
  • But if I can figure that out, then I will investigate “Very Low Cost ROS2 GoPiGo3 Mapping/Localization”
    • $4 Grove ultrasonic ranger for mapping, with only encoders for localization?
      (Really low cost ROS2 GoPiGo3: $129 GoPiGo3, $80 RPi, $4 Grove Ultrasonic Range sensor)
      I am sure the localization will be only close until the first turn, but it will be interesting to know how bad is “don’t expect much”
Status Update: First slam-toolbox generated map
    • view data topics
  • slam-toolbox installed and configured for ydlidar X4
  • ydlidar transform publishing for laser_frame to base_link
  • Confirmed /map publishing (at 1 map every 5 seconds) using 7% of CPU
  • Uses 40% of the Pi4B processor
  • Processor temp: 51-59degC
  • 7.7W (0.7A at 10.9v) Total Load On Battery
  • Managed to resurrect my desktop ROS2 Galactic VM and get rviz2 to display the map
    It’s accurate btw.
(That black square above the blue ROS2HH bot is Carl)
** THIS IS TOTALLY ON-BOARD THE GOPIGO3 PROCESSING **
(Displaying the map graphic is off-board)
All is not peaceful in ROS2HH land though:
  • Don’t know how to kill slam-toolbox (have to reboot the whole robot!)
  • If I drive ROS2HH bot forward, it appears in the map as he is going the opposite direction
  • Lidar is publishing its own transform, I think I need the GoPiGo3 node to publish all the transforms from the URDF.
I had something like that early on - was an issue with the positioning of the lidar on my URDF. So ensuring transforms are consistent sounds like the right approach.
/K
Is the right way to do that to launch a robot state and robot joint state publisher that reads the URDF?
I see in my Hands on ROS notes the robot and joint state publishers were launched in the rviz launch script on the desktop. I always thought that strange that the robot didn’t run these, but they seem to be the key to slam, and to visualization which as far as I could tell we’re only on the desktop.
I don’t think it should matter where they run, just as long as they are publishing from somewhere, and since I’m trying to put everything GoPiGo3 on the bot, I think I want/need them on the bot as well.
At the present my GoPiGo3 node publishes an odom to base_link tf, and the LiDAR is publishing an incorrect laser to base_link tf. I would like to have all the transforms coming from the URDF as a central configuration file.
I’ll have to go back and refresh my memory. If I recall not all transforms came from the URDF.
/K
V1 RESULT - CLOUD-INIT NOT RUNNING AT BOOT
Cloud-init was not running at boot, so networking could not be pre-configured.
NEW VERSION SOON…
I have a distinct memory of one of my files creating a transform outside the URDF, but right now I can’t find it looking through my GitHub repository. I’ll keep looking.
/K
Don’t worry about checking the “old”, I’ve got the mapping working with the GoPiGo3 generating the Odom to base_link and the LIDAR generating the laser to base_link and that is working well.
I’m going to investigate running the robot state and joint state publisher from URDF on the GoPiGo3. That just seems like the right place for my “everything you ever wanted to know about ROS2 (when you know nothing about ROS) on the GoPiGo3”.
If a user has ROS2 desktop (for rviz2) they can visualize everything, but I’m trying to make that completely optional to have a complete self-contained ROS2 GoPiGo3 robot with no dependancy on any “off-board processing”.
That’s great.
I re-flashed a micro SD-card. My GPG3 gets a solid green light, but still doesn’t show on the network (even when I connect an ethernet cable). I’ve dug a monitor and VGA cable out of the basement - tomorrow I should be able to trouble shoot directly. But too late for me tonight :slight_smile:
/K
No No, please drop testing that version. I am trying a new image of that system on which I performed
sudo cloud-init clean --logs
before shutting down.
This claims to re-enable the reading of the network-config file to establish the network.
Still researching the “headless network re-configuration” issue
I really thank you for your testing with that version 1.
I won’t spend too much time on it - I’m curious as to what’s going on.
/K
One thing to try might be to add:
ethernets:
        eth0:
            optional: true
            dhcp4: true
to the /boot/network-config file
ethernets:
        eth0:
            optional: true
            dhcp4: true
wifis:
  wlan0:
    dhcp4: true
    optional: true
    access-points:
      "your_SSID":
        password: "your_netpswd"
after flashing the image to the card (using the imager wifi/hostname/… setup), and see if it enables wired connection.
You may have to boot the system twice - I have confirmed that the network-config file gets copied to the /etc/netplan/50-cloud-init.yaml on the first boot, so perhaps on the second boot it will get used.
I just tried this with my new image that I did the sudo cloud-init clean --logs in before shrinking and confirmed that the 1st boot copied the network-config to the 50-cloud-init.yaml and the second boot used the new info.
To try a new SSID that the sys had never attached to before, I setup my iPhone hotspot and eth0 into the network-config file.
First boot:
  • it connected to the old SSID/passwd, so I was able to log in
  • It showed my ethernet IP in the login message
  • I installed:
sudo apt install -y net-tools wifi-tools
so that
ifconfig
iwconfig
were available to see info about the connections.
Second boot:
  • it did not connect with the old SSID/passwd,
  • I was able to log in via the ethernet
Third boot (with iPhoneX hotspot active):
  • it showed the wifi IP for the connection to the iPhoneX hotspot
Maybe three boots is the secret?
I am able to see the user file system when I mount the disk on my linux laptop, and saw that the cloud-init clean did not remove the /etc/netplan/50-cloud-init.yaml. I think that explains the need for a few boots. I’m building a new shrunk image without that file, and will post it after some more tests.
Just for future reference.
Initial boot - failed to connect to wifi. Actually got hung up on log-in. I meant to record at what stage, but then the message went off the screen before I transcribed it- had to use ctrl-c to get a prompt. Wouldn’t connect via ethernet either when I plugged in a cable after booting. There was no /boot/network-config file when I looked on the ubuntu file system. Shut down.
I rebooted - I had the screen set up this time. Noticed one of the boot messages was that eth0 and wlan0 were “false”. Didn’t hang this time when I logged in, but no network connection. Shut down.
Modified the network-config file on the SD card to include eth0. Also noticed there was a “renderer” line for wifi - I removed that since you didn’t show it.
First boot: eth0 and wlan0 “false” on boot messages; no network connection (tried ping and not showing on my wifi control panel dashboard)
Second boot: same boot messages; not online as before.
Third boot: same result
Ok - three strikes and I’m out. No more exploration of this version. I’ll test the new version as soon as I can.
/K
