Cannot run Basic_Robot_Control
I just finished assembling my gopigo and was able to connect it to my local wireless network, but every time I try to run the basic robot control program in terminal it says that there is “no such file in the directory.” Also the first line if text the appears every time I open terminal it reads “access control disabled, clients can connect from any host.” I don’t know what to do at this point. I did update the firmware on the gopigo and then did a reboot, but the problem still exists.
I understand your disappointment.
Could you post the exact line you’re using to run the basic control program?
As for “access control disabled, clients can connect from any host.” it’s a side effect of running the Pi without a monitor. That’s nothing to worry about.
