I am intending to create a crude autonomous robot using the GoPiGo Robot Starter Kit and a Raspberry Pi Camera. I intend to code ROS packages in C++ and OpenCV to perform crude computer vision and autonomously navigate the robot.
Are these things possible or will I run into problems or limitations? Any insight from you guys would be greatly appreciated
Do you think the following requirements are met by the GoPiGo Robot Starter Kit and a Raspberry Pi Camera?
- Install and run ROS on the GoPiGo Raspberry Pi micro-controller
- Perform computer vision video processing with not too high latency. Do you think the micro-controller can handle a ROS package/packages that will be processing the video stream (goal is to process/handle ~25 frames/second).
- API to move the GoPiGo wheels, turn etc. How is this setup? Is there an API I can use?
