Loose Servo on GoPiGo[SOLVED]
I have my GoPiGo assembled with the Servo residing on the top of the case. I put all of the screws in properly (or so I thought), attached the sensor, but it’s very wobbly. Tightening the screws does not keep the servo from wobbling, it’s still very loose.
Does anyone have any solutions for making the servo that holds the sensor more sturdy?
Thank you in advance!
I’m using Sugru to keep them in place.
I have never heard of Sugru before, thank you for the tip! Is it working well for you?
I’m loving Sugru! It’s like playdoh that turns into plastic when it solidifies. I use it wherever there are screw tips that little fingers can get hurt on. Also on cables that tend to break. Tons of uses for Sugru :smiley:
Thank you so much for the recommendation!
