Hi -
I’m just getting started with GrovePi. I followed all the setup instructions (including updating GrovePi references with NuGet in my project, and connecting the two sensors correctly), but when I ran the sample program buttonbuzzer at this line:
System.TypeLoadException occurred
HResult=0x80131522
Message=Could not find Windows Runtime type ‘Windows.Devices.I2c.I2cConnectionSettings’.
Source=
StackTrace:
at GrovePi.DeviceBuilder.BuildGrovePiImpl(Int32 address)
at GrovePi.DeviceBuilder.DoBuild[TSensor](Func`2 factory)
at GrovePi.DeviceBuilder.ButtonSensor(Pin pin)
at ButtonBuzzer.StartupTask.Run(IBackgroundTaskInstance taskInstance) in C:\mytests\Button_Buzzer\StartupTask.cs:line 56
Hi -
I followed the tutorial exactly, and when I run it, I get the following 1
error and the 4 warnings. (Naturally, it’s the error I’m more worried
about.) This happens with both HelloWorldBlinky and ButtonBuzzer. (I get
the same error both times.)
Thanks for your help in getting this to work!
Severity Code Description Project File Line Suppression State
Error DEP6720: Failed to deploy package ‘Core CLR’
(E0999A8F-0200-4738-AE1E-B45742BE6B6B). Package is not defined for OneCore.
HelloWorldBlinky
Warning Certificate file ‘HelloWorldBlinky_TemporaryKey.pfx’ not found.
HelloWorldBlinky
Warning The certificate specified is not valid for signing. For more
information about valid certificates, see http://go.microsoft.com/fwlink/?LinkID=241478. HelloWorldBlinky
Warning CS1998 This async method lacks ‘await’ operators and will run
synchronously. Consider using the ‘await’ operator to await non-blocking
API calls, or ‘await Task.Run(…)’ to do CPU-bound work on a background
thread. HelloWorldBlinky
C:\Users\Administrator\Desktop\GrovePi-master\Software\CSharp\Samples\HelloWorldBlinky\HelloWorldBlinky\StartupTask.cs
58 Active
Warning CS0168 The variable ‘ex’ is declared but never used HelloWorldBlinky
72 Active
After failing in running any of the Windows IoT apps, I set up Raspian for
Robots, in the hope of getting something working. I seem to be having some
i2c problem, but I’m not sure what else. (i2cdetect doesn’t detect
anything). I’ve updated the firmware and done everything else I could think
of, and I can’t get grove_led_blink.py to work, or anything else. (I’ve
been at this for hours.) Here is my log.txt from alltest.sh. Please
help! I’m really trying to get this to work!
Dear John,
IT’S ALL WORKING NOW!! Thanks for your help. I think it was the
permissions thing you fixed, because went I just went to try again,
everything was finally fine. I’m so happy!!
