2-coil latching relay sets off unwantedly
Hi guys,
so I made this greenhouse with humidity, light sensor etc. If the light is too low the 2-coil latching relay is supposed to switch a usb led-light on.
This works really well, unfortunately the relay switches on and off very fast unintentionally all the time. So when I check for the temperature, the light or the moisture for example, the relay switches on and off for about 1 second.
I can even just run a python script for the sensors:
import grovepi
moisture_s=2
light_s=1
temp_hum_s=2
moisture=grovepi.analogRead(moisture_s)
light=grovepi.analogRead(light_s)
[temp,hum]=grovepi.dht(temp_hum_s)
Same thing happens.
How is this possible?
Hi @gollium,
Could you connect the DHT sensor to port D4 (you need to assign 4 as value)?
If you do this, does the relay still switch very fast?
And to which port is the relay connected?
Other than the suggestion I gave you up there, you could also start adding a sensor at a time and see when the relay starts switching without any reason.
And last, please tell us the firmware version of it. We want to be sure you have the latest.
