i need help!! I just tried to download the raspbian for robot image. And also tried to update dexter software. while in the progress updaing the software, I saw the screen indicated restart press “exit” then reboot again. Di software update icon change to other icon as per attached. And I also try to open the scratch which fail to open. what should i do for making system be normal?
Thank John ! But I have already format the image and reinstall the image . But now another problem. The scratch couldn’t open and keep showing me “grove pi scratch: scratch connection error retrying” and “scratch is either not opened or remote sensor connection aren’t enabled”. What should I do in order to open the scratch normally? Thank in advance!
DI Update currently has an issue when it tells the user to reboot, yet it’s not really done. You’re not at fault here, DI Update is.
It’s really done when it says
By the fact the icon is missing, it’s fairly certain that the update didn’t complete.
To get back to a working condition, you will have to do the following:
Hi ttsiang, the DI Update is stable; it just needs to be able to run all the way through to the end. If you stop in the middle, it can end up not fully updated.
So if you ran
cd ~
sudo sh update_backup.sh
Are the icons back to normal on the desktop? Maybe you can post a screenshot as well, it might help us understand more about what’s happening on the Desktop or the Raspbian right now.
