Can’t get any audio to come out of my gopigo3 using Raspbian for robots.
Anyone else had this issue?
How I setup audio for my GoPiGo3 “Carl” robot:
=== raise the sound playback, and capture levels
alsamixer (h for help)
8 to set playback to 85%
s select USB PnP Sound Device
Tab till [Capture] is highlighted
8
up arrow once to 81%
Esc to exit alsamixer
alsactl store 0 to save settings
=== Test audio
aplay /usr/share/sounds/alsa/*
if no audio:
amixer to see what is current setting: (0=auto, 1=analog, 2=HDMI)
sudo amixer cset numid=3 1 (set to output sound to 3.5mm jack
try again:
========== If audio output is too soft =======
if soft: alsamixer
s (select card)
downarrow to “0 bcm2835 ALSA”
8 (4=default loudness, 8=100%, 9=125%)
Escape (press Esc)
then make setting default:
sudo alsactl store 0
==== espeak is already installed in Raspbian for Robots
# This is my speak.py module containing say(phrase) function:
#!/usr/bin/python
# speak.py Speaker utilities
# say(phrase) (includes safe use of apostrophe in quoted strings and quotes in apostrophed strings)
import subprocess
def say_espeak(phrase):
phrase = phrase.replace("'","")
phrase = phrase.replace('"',' quote ')
subprocess.check_output(['espeak -ven+f3 -s200 "%s"' % phrase], stderr=subprocess.STDOUT, shell=True)
def say(phrase):
say_espeak(phrase)
# ##### MAIN ####
def main():
# say("hello from speak dot p y test main")
# say_espeak("whats the weather, long quiet?")
say("This phrase contains an apostrophe which isn't allowed")
say('This phrase contains "a quoted word" ')
say("My name is Carl. I don't know Pogo. Never met the little bot")
if __name__ == "__main__":
main()
The next to last line is:
if __name__ == “__main__”:
make sure the double underscores are there.
Thanks @RobertLucian - One of these days the triple back quote markup will stick in my brain.
No problem
. I know it’s kinda counterintuitive, so it can be confusing at times.
