Hi, the servos that come with Dexter kits like GrovePi usually turn 180 degrees max. Are there any servos available that turn 360 degrees?
Hi @roman7927,
I don’t know if continuous rotation servos are what you need, but maybe you can check this:
But bear in mind, with this one you can’t control the position, only the speed at which it rotates.
This is probably what you need, but it has been discontinued unfortunately:
Hope this gives you at least an idea of what you need to find.
