I am curious how you are managing the assignment of new sensor command numbers?
I have three new parts that I am working with that are currently not supported by the Grove Pi. Each of these will require that I write the code in the firmware to work with them. I’ve looked around, and have not seen a common header that is being maintained with these numbers within the firmware, and I was wondering how I might want to select or use numbers for these new sensors?
There are no strict rules as such for the assignment of the new sensor command numbers but these are the pointers that we usually follow:
Do not use a number which is already being used
The number should be between 0-255
If you have a sensor which needs a lot of functions to be implemented on the firmware, then it would be better to use sequential numbers for it, like the 4 digit display uses numbers from 70 to 79.
If you just want to implement 1 function, then it might be better to just continue from 13 or 22
