Audio on the GoPiGo3 has been a bit of a kludge up till now:
- A right-angle 3.5mm audio plug rubs against the GoPiGo3 wheel,
- Powering a speaker connected to the 3.5mm audio has to be solved:
- For Dave I get power from a processor board USB-A port
- For Carl I get power from the GoPiGo3 AD2 port
- A good quality powered speaker is actually quite heavy
- The RaspberryPi3 and 4 have no mic in:
- on Carl I use a 3.5mm plug mic into a USB audio adapter (configuring ALSA for that was a nightmare)
- Dave doesn’t use speech reco - his processor is fully loaded with no cycles to spare
Now they take the 3.5mm jack off completely and put the audio on two micro HDMI connectors. I guess one of the Pi5 USB-A connectors will go to a USB audio adapter to drive Dave’s speaker. Forgot to order one of those. I’lll have to rewire the speaker power to the new BIGGER 5v power supply.
