I cannot get the avrdude to work, please help!
I ran avrdude -c gpio -p m328p
this check.
avrdude done. Thank you.
And this is what I get when I run the troubleshooter
GoPiGo Troubleshooting Script
Adding permissions to the scripts
./all_tests.sh: line 10: cd: /home/pi/Desktop/GoPiGo/Troubleshooting/: No such file or directory
Check space left
/dev/root 6.3G 3.2G 2.9G 53% /
devtmpfs 428M 0 428M 0% /dev
tmpfs 87M 276K 86M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 173M 0 173M 0% /run/shm
/dev/mmcblk0p5 60M 20M 40M 33% /boot
/dev/mmcblk0p3 27M 416K 25M 2% /media/SETTINGS_______
Check for dependencies
python 2.7.3-4+deb7u1 install ok installed
python-pip 1.1-3 install ok installed
git 1:1.7.10.4-1+wheezy3+rpi1 install ok installed
libi2c-dev 3.1.1+svn-1 install ok installed
python-serial 2.5-2.1 install ok installed
python-rpi.gpio 0.6.2~wheezy-1 install ok installed
i2c-tools 3.1.1+svn-1 install ok installed
python-smbus 3.1.1+svn-1 install ok installed
arduino 1:1.0.1+dfsg-7 install ok installed
minicom 2.6.1-1 install ok installed
scratch 1.4.20131203-2 install ok installed
wiringPi Found
wiringPi Found
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Sony
- Device tree is enabled.
- This Raspberry Pi supports user-level GPIO access.
-> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-0
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
|__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
|__ Port 5: Dev 4, If 0, Class=vend., Driver=rt2800usb, 480M
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
this check.
Checking I2C bus for devices
Checking I2C bus 0
70: – -- – -- – -- – --
Checking I2C bus 1
Checking for firmware version and CPU Speed and Voltage
python: can’t open file ‘/home/pi/Desktop/GoPiGo/Software/Python/tests/firmware_version_cpu_test.py’: [Errno 2] No such file or directory
python: can’t open file ‘/home/pi/Desktop/GoPiGo/Software/Python/tests/enc_tgt_test.py’: [Errno 2] No such file or directory
Log has been saved to Desktop. Please copy it and send it by email or upload it on the forums
