Sorry to bump this post but I have the same problem than Karan :
Fresh Raspberry install (Raspbian and Arduberry installed from script : blink sketch fail (see below). Next I tried your Wheezy img : idem
avrdude -c gpio -p m328p
gives
this check.
avrdude done. Thank you.
avrdude -c gpio -p m328p -F
gives
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
And troubleshooting script gives :
troubleshooting_script_v1
Check for dependencies
python 2.7.3-4+deb7u1 install ok installed
python-pip 1.1-3 install ok installed
git 1:1.7.10.4-1+wheezy1+rpi2 install ok installed
libi2c-dev 3.1.0-2 install ok installed
python-serial 2.5-2.1 install ok installed
python-rpi.gpio 0.5.7-1 install ok installed
i2c-tools 3.1.0-2 install ok installed
python-smbus 3.1.0-2 install ok installed
arduino 1:1.0.1+dfsg-7 install ok installed
minicom 2.6.1-1 install ok installed
scratch 1.4.20131203-2 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Setup for Serial for BrickPi
Clock speed Configured
Serial Port Enabled
Serial Port Login Already Disabled
Hardware revision
gpio version: 2.20
Copyright (c) 2012-2014 Gordon Henderson
Raspberry Pi Details:
Type: Model B, Revision: 2, Memory: 512MB, Maker: Sony
Read pins
+-----+-----+---------+------+---+-Model B2-+---+------+---------+-----+-----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | ALT0 | 1 | 3 || 4 | | | 5V | | |
| 3 | 9 | SCL.1 | ALT0 | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 0 | 7 || 8 | 1 | ALT0 | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 1 | ALT0 | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | IN | 0 | 11 || 12 | 0 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 0 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 0 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | OUT | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | IN | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | OUT | 0 | 23 || 24 | 1 | OUT | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | ALT0 | CE1 | 11 | 7 |
| 28 | 17 | GPIO.17 | IN | 0 | 51 || 52 | 0 | IN | GPIO.18 | 18 | 29 |
| 30 | 19 | GPIO.19 | IN | 0 | 53 || 54 | 0 | IN | GPIO.20 | 20 | 31 |
Check I2C
00: -- 04 -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
70: -- -- -- -- -- -- -- --
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
=USER STATS=
BrickPi Found
Arduberry Found
grovePi Found
GoPiGo Not Found
BrickPiStatus
BrickPi Not Found (ERR)
Help !!!
