Best way to cut thick plastic panels?
Greetings!
I want to add a Vellman 3" touchscreen to the top of Charlie’s top plastic panel by cutting a rectangular hole to give access to the GPIO pins.
I’m sure I could hack a “butt ugly” hack-job of an opening. However, I’d rather make it look at least semi-decent.
  1. I do not have a laser cut-out tool.
  2. I do not have a 3D printer.
  3. I do not have a fancy 3D milling machine.
Any ideas?
Would a jigsaw with a thin blade work and do a reasonable job?
Update:
Went to a local hardware store and asked about cutting relatively thick acrylic plastic.
I was given a hand-held manual jig saw and some fine-toothed blades with the advice to work slowly so as to not over-heat the plastic and clog the blade.
More later.
