@Saxon,
Can you give a few more details about what worked and what not. What did the browser show when you were trying to use the browser streaming robot in the browser and what were the messages shown in the terminal. Can you post a few screenshots too.
It looks like the URL that you are using to access the browser streaming robot needs to be changed a bit.
The URL to access the browser streaming robot is dex.local:98. Try this URL from a computer different from the one in which you are running the robot_web_server.py.
Sorry didn’t notice that your username is dex_32. So should just try using dex_32.local:98 on the browser.
Also try using dex.local:98 without any www prefixing it.
Hi Shoban,
I have return to 1st principle of Miguel-MJPG Stream code with 2 tests chassis.:-
Dex Chassis/Dex32_SD
Rasp14 Chassis/Rasp14_SD
With proof that Rasp14 works fine with Miguel-MJPG, I can then vary the combination of browsers to identify what does and does not work.
I am pleased with the Dex Chassis and lucky to discover the forum
Regards
Saxon
