Hey there, currently I am running a python script that uses a button attached to the GrovePi using a screw terminal. Until now it had only one function in each “mode”, however I would like to add short and long press functions without (further) delaying the program. Any thoughts on this?
Currently this is my function to read the button:
def pushcallback():
readingpush = grovepi.digitalRead(pinpushbutton)
time.sleep(0.2)
if (readingpush == grovepi.digitalRead(pinpushbutton)):
return readingpush
Hi @jeroenveenvan,
Here are some suggestions for you:
Use threads (one for each button) - it’s going to let your main program run just as before.
Read more frequent the button’s state in the same period of time: i.e.: instead of reading the button’s state, then wait 200ms and then check again, try reading the button’s state for say … 5 times during those 200ms.
Use some statistical analysis for eliminating noise during the reads - maybe the user doesn’t push as with much force the button in order to trigger it, so I think this approach is going eliminate these errors.
What do you think?
I know the topic is quite old, but I did want to share my own solution. I didn’t want to be bothered using threads (still don’t know how to use them… my bad!) This is a very simple solution which works good /enough/.
def pushcallback():
timepush = time.time()
time.sleep(0.05)
if (readingpush != grovepi.digitalRead(pinpushbutton)):
return None
else:
if (readingpush == 0):
return 0
while (readingpush == grovepi.digitalRead(pinpushbutton)):
time.sleep(0.05)
if (grovepi.digitalRead(pinpushbutton) == 0):
newtime = time.time() - timepush
print newtime
return newtime
