I enabled the I2C-Interface and connected the GrovePi to my Raspberry (4 Model B). Then I ran the command sudo curl -kL dexterindustries.com/update_grovepi | bash
but it exits with the following last lines:
Installed /usr/local/lib/python3.9/dist-packages/smbus_cffi-0.5.1-py3.9-linux-armv7l.egg
Searching for scipy
Reading Links for scipy
Downloading
Best match: scipy 1.8.1
Processing scipy-1.8.1.tar.gz
Writing /tmp/easy_install-nldwglyt/scipy-1.8.1/setup.cfg
Running scipy-1.8.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-nldwglyt/scipy-1.8.1/egg-dist-tmp-dbxc9vib
/tmp/easy_install-nldwglyt/scipy-1.8.1/setup.py:486: UserWarning: Unrecognized setuptools command (’-q bdist_egg --dist-dir /tmp/easy_install-nldwglyt/scipy-1.8.1/egg-dist-tmp-dbxc9vib’), proceeding with generating Cython sources and expanding templates
warnings.warn("Unrecognized setuptools command (’{}’), proceeding with "
Error: ‘pybind11’ must be installed before running the build.
error: Setup script exited with 1
I have no idea what to do know. It is a fresh install of Raspberry Pi OS. If someone could provide me with easy instructions on what to know, I would be much obliged.
I’m just using it because we have this project in school. I don’t normally do these things and have little experience with Raspberry Pi and Linux, so please bear with me.
Note: I had to remove the link where it says download after searching for scipy, so it’s blank there.
