Cannot read NTX sensors using new image
I have set up the brickpi according to the quickstart guide on your website.
I have used the Dutch langauge so my son can also work with it.
Now the motor example works, motors work, the ultrasonic sensor works, but the on/off switch does not work.
I have attached a screenshot, my question:
How can I set the blue sensor value box (in Dutch “waarde van sensor”) in your example it is called S1, but as you can see if I clcik on the drop down combobox it only says (“schuif”,Licht,Geluid, …) all nicely translated into Dutch but not S2, S1 etc …
to be precise the Touch sensor does not work anymore.
So my suspicion is that there is a mappping from scratch to the word “TOUCH” in the second scratch block(see ss)
can anyone confirm this?
Can I change it to allign with the Dutch translations?
If I change the work TOUCH the listener to the brickpi crashes…
