OK… updated the Pi setup as desktop (directly plugged in to router).
Using LXTerminal I ran:
sudo apt-get update
sudo apt-get upgrade
then
`hostname -I
Revealed 10.1.1.5 169.254.6.235
Now I can ping both those from my Macbook.
annas-mbp-3:~ Eldon$ ping 10.1.1.15
PING 10.1.1.15 (10.1.1.15): 56 data bytes
64 bytes from 10.1.1.15: icmp_seq=0 ttl=64 time=2.842 ms
64 bytes from 10.1.1.15: icmp_seq=1 ttl=64 time=3.924 ms
64 bytes from 10.1.1.15: icmp_seq=2 ttl=64 time=28.275 ms
64 bytes from 10.1.1.15: icmp_seq=3 ttl=64 time=27.897 ms
64 bytes from 10.1.1.15: icmp_seq=4 ttl=64 time=4.192 ms
64 bytes from 10.1.1.15: icmp_seq=5 ttl=64 time=4.963 ms
Request timeout for icmp_seq 6
64 bytes from 10.1.1.15: icmp_seq=7 ttl=64 time=4.121 ms
64 bytes from 10.1.1.15: icmp_seq=8 ttl=64 time=23.899 ms
64 bytes from 10.1.1.15: icmp_seq=44 ttl=64 time=4.086 ms
64 bytes from 10.1.1.15: icmp_seq=45 ttl=64 time=4.315 ms
^C
— 10.1.1.15 ping statistics —
46 packets transmitted, 42 packets received, 8.7% packet loss
round-trip min/avg/max/stddev = 1.342/7.144/28.275/7.222 ms
annas-mbp-3:~ Eldon$ ping 169.254.6.235
PING 169.254.6.235 (169.254.6.235): 56 data bytes
64 bytes from 169.254.6.235: icmp_seq=0 ttl=64 time=8.201 ms
64 bytes from 169.254.6.235: icmp_seq=1 ttl=64 time=5.577 ms
64 bytes from 169.254.6.235: icmp_seq=12 ttl=64 time=4.642 ms
64 bytes from 169.254.6.235: icmp_seq=13 ttl=64 time=1.389 ms
64 bytes from 169.254.6.235: icmp_seq=14 ttl=64 time=4.356 ms
^C
— 169.254.6.235 ping statistics —
15 packets transmitted, 15 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 1.389/6.286/17.390/4.040 ms
I can ssh to the raspberrypi
annas-mbp-3:~ Eldon$ ssh pi@raspberrypi.local
The authenticity of host ‘raspberrypi.local (10.1.1.15)’ can’t be established.
RSA key fingerprint is 7f:27:c6:a2:15:9e:10:ca:3d:69:20:fe:d6:b6:d3:38.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added ‘raspberrypi.local,10.1.1.15’ (RSA) to the list of known hosts.
pi@raspberrypi.local’s password:
Linux raspberrypi 4.1.7-v7+ #817 SMP PREEMPT Sat Sep 19 15:32:00 BST 2015 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
I can also VNCviewer in wirelessly too and bring up the raspberryPi homescreen.
But… plugging the ethernet cable directly into my Macbook, gives the same original problem or request timeout.
Last login: Tue Mar 10 02:05:41 2015 from dexter-probook.local
pi@raspberrypi ~ Write failed: Host is down
annas-mbp-3:~ Eldon ping 169.254.6.235
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
Am I stuck in some weird connectivity problem between my macbook and the raspberrypi? Can I just connect up the raspberrypi via the router and VNC into it to program it that way? Help!? I’m trying to troubleshoot it but this has me stumped…
