I tried to run the python grove_temperature_sensor.py .But when i try the code i get following error:
File "grove_temperature_sensor.py", line 57, in <module>
temp = grovepi.temp(sensor,'1.1')
File "/home/pi/GrovePi/Software/Python/grovepi.py", line 245, in temp
a = analogRead(pin)
File "/home/pi/GrovePi/Software/Python/grovepi.py", line 227, in analogRead
return number[1] * 256 + number[2]
TypeError: 'int' object has no attribute '__getitem__'
GrovePi Troubleshooting Script
Adding permissions to the scripts
chmod: changing permissions of ‘software_status.sh’: Operation not permitted
chmod: changing permissions of ‘avrdude_test.sh’: Operation not permitted
chmod: changing permissions of ‘i2c_test1.sh’: Operation not permitted
chmod: changing permissions of ‘firmware_version_test.sh’: Operation not permitted
tee: log.txt: Permission denied
Check space left
/dev/root 7.2G 4.4G 2.6G 64% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 201M 262M 44% /dev/shm
tmpfs 462M 6.4M 456M 2% /run
tmpfs 462M 0 462M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 21M 21M 50% /boot
tmpfs 93M 0 93M 0% /run/user/1000
Check for dependencies
git 1:2.1.4-2.1+deb8u3 install ok installed
libi2c-dev unknown ok not-installed
dpkg-query: no packages found matching arduino
dpkg-query: no packages found matching minicom
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 not there (ERR)
spi-dev not there (ERR)
Hardware revision
gpio version: 2.44
Copyright (c) 2012-2017 Gordon Henderson
Raspberry Pi Details:
Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Embest
* Device tree is enabled.
*--> Raspberry Pi 2 Model B Rev 1.1
* This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 001 Device 006: ID 0a5c:bd1e Broadcom Corp.
Bus 001 Device 005: ID 03f0:034a Hewlett-Packard
Bus 001 Device 004: ID 046d:c534 Logitech, Inc.
|__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 6, If 0, Class=Vendor Specific Class, Driver=brcmfmac, 480M
Raspbian for Robots Version
Hostname
raspberrypi
Checking for Atmega chip
./avrdude_test.sh: line 6: avrdude: command not found
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00: -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
File "/home/pi/GrovePi/Software/Python/grove_firmware_version_check.py", line 40, in <module>
print("GrovePi has firmware version: %s" %grovepi.version())
File "/home/pi/GrovePi/Software/Python/grovepi.py", line 266, in version
return "%s.%s.%s" % (number[1], number[2], number[3])
