This is a somewhat old write-up of the project. My guess is that with our new Raspbian for Robots, you should enter dex.local, not raspberrypi.local
I haven’t tried it myself, so I’m not 100% it will work.
I can control the motors on GoPiGo through webbrowser except servo and i don’t get streaming video.
I get this error:
mmal: mmal_component_create_core: could not create component ‘vc.ril.camera’ (1)
Error : Failed to create camera component
Error : uuuuuuuuUnable to create camera component
Stop
Drakenridder: Also sounds like you might not have the camera installed or the camera module installed. Are you using Raspbian for Robots or another image?
Thanks! I found the problem there was some damage to cable of camera. Once replaced it worked. Not 100% because i can see images and i can move around but can’t manipulate pan/tilt mechanisme of camera because i can’t see the button on web browser. And yes i try to use /raspberry-pi-browser-streaming-robot/ and i also want to add 1 O2 sensor and 1 buzzer! It 's for a school project.
I found the second joystick of robot streamer for controling tilt/pan servo. It was invisible because it was dissabled in index.html. I 'm still missing a piece of code for controlling the pan/tilt servo with this button. Unfortunately i’m not a programmer so I hope someone knows whats missing.
