Why I can’t connect to my wifi with my wireless adapter on my GoPiGo with a Raspberry B+?
I tried “sudo ifconfig” but my adapter doesn’t appear.
I have a TP-LINK Wireless N USB Adaptater.
Thank you for your help bye.
It looks like that this might be a driver problems. I found a couple of links suggesting this: http://raspberrypi.stackexchange.com/questions/15380/wifi-usb-adapter-not-detected, https://www.raspberrypi.org/forums/viewtopic.php?f=91&t=29752&start=25 and http://laurenthinoul.com/how-to-install-tp-link-tl-wn725n-on-raspberry-pi/. You should search on the Raspberry Pi forums for a solution and try to get it to work.
I can’t update the drvers D:
Can you explain a bit more about what all you tried. Updating the drivers is still a bit difficult.
If you are just starting out you should get a wifi adapter that works out of the box with the Pi or get it directly from us: http://www.dexterindustries.com/shop/wifi-dongle-for-raspberry-pi/.
-karan
