Hello I have same problem! wit Raspberry 4 with GroovePi+ My logs are:
Check space left
/dev/root 58G 7.3G 49G 14% /
devtmpfs 334M 0 334M 0% /dev
tmpfs 463M 0 463M 0% /dev/shm
tmpfs 463M 6.3M 456M 2% /run
tmpfs 463M 0 463M 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 52M 201M 21% /boot
tmpfs 93M 0 93M 0% /run/user/1000
Check for dependencies
python 2.7.16-1 install ok installed
python-pip 18.1-5+rpt1 install ok installed
git 1:2.20.1-2+deb10u1 install ok installed
libi2c-dev 4.1-1 install ok installed
python-serial 3.4-4 install ok installed
python-rpi.gpio 0.7.0~buster-1 install ok installed
i2c-tools 4.1-1 install ok installed
python-smbus 4.1-1 install ok installed
dpkg-query: no packages found matching arduino
dpkg-query: no packages found matching minicom
scratch 1.4.0.6~dfsg1-6 install ok installed
find: ‘/proc/4660’: No such file or directory
find: ‘/proc/4665’: No such file or directory
find: ‘/home/pi/thinclient_drives’: Permission denied
find: ‘/run/user/1000/gvfs’: Permission denied
wiringPi Not Found (ERR)
find: ‘/proc/4809’: No such file or directory
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.50
Copyright © 2012-2018 Gordon Henderson
Raspberry Pi Details:
Type: Unknown17, Revision: 01, Memory: 1024MB, Maker: Sony
- Device tree is enabled.
*–> Raspberry Pi 4 Model B Rev 1.1
- This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1bcf:0005 Sunplus Innovation Technology Inc. Optical Mouse
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
Hostname
raspberrypi
Checking for Atmega chip
User configuration file is "/home/pi/.avrduderc"
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or /dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version
File “/home/pi/Dexter/GrovePi/Software/Python/grove_firmware_version_check.py”, line 37, in
import grovepi
File “/home/pi/Dexter/GrovePi/Software/Python/grovepi.py”, line 52, in
import di_i2c
ImportError: No module named di_i2c
I spent an hours to solve this and solution is nowhere
Can someone help
Thank you Tomas
