Can’t get gopigo to drive. Green power button never stops flashing. However I can connect it through my laptop. The camera even displays on my laptop. No responses to any driving commands.
Help please.
Kevin
Help please.
Kevin
Check battery is charged fully. Low or no battery = no driving
If you know to run a python program - create test.py or run in Jupyter:
# battery.py - run: python3 battery.py
# Create an EasyGoPiGo3 object, then use the volt() method to check battery voltage
import easygopigo3
egpg = easygopigo3.EasyGoPiGo3()
print("Battery:", egpg.volt()+0.8 )
If you are using Blockly, you can do the same - I don’t have Blockly running right now to try it.
Flashing green LED means startup/shutdown/GoPiGo software not installed.
You need to tell us what pi you’re using, what OS, and if not the official GoPiGo OS v 3.1, (3.1.1?), what you’re using. If you’re not using the GoPiGo3 OS, did you “curl” down the GoPiGo software and libraries?
We also need to know what version of the GoPiGo you are using, along with the version of your Pi, as well as the software/OS and version.
Turns out my issues resulted from connecting the motors into the wrong ports. I had them switched.
Ooh! That’ll do it. . .
You are now a card-carrying member of the Dexter Industries Robotics Society. ![]()
My favorite?
“It works MUCH better with power!” (And a SD card installed.
