Can the mjpg_streamer be told to capture at a higher frame rate?
Where can I specify this?
I tried experimenting with both of these:
raspistill -w 640 -h 480 -q 5 -o /tmp/stream/pic.jpg -tl 100 -t 9999999 -th 0:0:0 -n > /dev/null 2>&1&
echo "raspistill started"
fi
if pgrep mjpg_streamer > /dev/null
then
echo "mjpg_streamer already running"
else
LD_LIBRARY_PATH=/opt/mjpg-streamer/ /opt/mjpg-streamer/mjpg_streamer -i “input_file.so -f /tmp/stream -n pic.jpg” -o “output_http.so -p 9000 -w /opt/mjpg-streamer/www” > /dev/null 2>&1&
echo “mjpg_streamer started”
But no luck.
If I can change the frame rate, I can have nicer local video coming from GoPiGo.
Any ideas?
Thanks in advance.
