Checking GoPiGo3 Software Versions
My “Versions.txt”
How to Check Versions of GoPiGo3 Hardware and Software
=== Check version of Raspbian (basis for R4R)
cat /etc/os-release
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
=== Check version of Raspbian For Robots Kernal
uname -a
=== Check version of Python
dpkg -s python python3 | grep Version
Version: 2.7.13-2
Version: 3.5.3-1
=== Check version of GoPiGo3 Firmware
cd ~/Dexter/GoPiGo3/Troubleshooting/
bash hardware_and_firmware_test.sh
Checking for hardware, and checking hardware and firmware version.
Manufacturer    :  Dexter Industries
Board           :  GoPiGo3
Serial Number   :  ...0B1F
Hardware version:  3.x.x
Firmware version:  1.0.0
Battery voltage :  9.62
5v voltage      :  5.063
=== Check version of Python GoPiGo3 package
pip freeze | grep gopigo
  gopigo3==1.2.0
=== Check version of Python DI Sensors package
pip freeze | grep DI-Sensors
  DI-Sensors==1.0.0
=== Check version of OpenCV
pip freeze | grep opencv
   opencv -contrib-python==3.4.4.19
=== Check installed version of ~/Dexter/GoPiGo3 software
pushd ~/Dexter/GoPiGo3
git rev-parse HEAD
  gives the hash code for the last commit.
Once you get that hash code, you can use it in this URL format:
https://github.com/DexterInd/GoPiGo3/commit/<<your-commit-hash-here>>
Put it in your browser and that will take you to the version you have in GitHub.
You can check the dates and see how far behind your version is from the latest one.
(Click on DexterInd/GoPiGo3 repository, click on <clock-face> XXX commits to see what
 has changed...
 - then backup your card,
 - then pick one of the following to update whole R4R (don't forget to reboot after):
   - run the desktop "DI Software Update",
   - sudo curl -L dexterindustries.com/update_r4r | bas
=== Check installed version of Raspbian for Robots
cat ~/Dexter/Version
V 9
This version of Raspbian was modified by Dexter Industries on the Stretch Raspbian Build.
This version was updated on 26th of June 2018.
Start: Wed Mar 27 07:30:56 EDT 2019
End: Wed Mar 27 07:36:17 EDT 2019
- (no longer works)
pushd ~/di_update/Raspbian_For_Robots
git rev-parse HEAD
https://github.com/DexterInd/Raspbian_For_Robots/commit/<<your-commit-hash-here>>
