Co2 sensor not working
hi,
I´m just trying to get the Co2 MH-Z16 up and running. I´m using a raspberry pi 3 b+ wit a grove pi+. So far i disabeld serial communication, diabeld the blothoth on s0 and the Sensor is connected to the priser port of the grove pi+. When im using the python Co2 test script (https://github.com/DexterInd/GrovePi/tree/master/Software/Python/grove_co2_sensor) i get the following output:
_Traceback (most recent call last):_
_  File "/ directory/sensor.py", line 7, in <module>_
_    [ppm,temp]= co2.read()_
_  File "/directory/grove_co2_lib.py", line 24, in read_
_    ser.write(self.cmd_get_sensor)_
_  File "/directory/serialposix.py", line 518, in write_
_    d = to_bytes(data)_
_  File "/directory/serialutil.py", line 63, in to_bytes_
_    raise TypeError('unicode strings are not supported, please encode to bytes: {!r}'.format(seq))_
_TypeError: unicode strings are not supported, please encode to bytes: 'ÿ\x01\x86\x00\x00\x00\x00\x00y'_
thats the problem so far…
hi again,
i came a little bit fürther… by changing the codeline in the python libary at line 13 to:
cmd_get_sensor = b"\xff\x01\x86\x00\x00\x00\x00\x00\x79"
the bytes seem to be send but i get the following error message:
  File "/home/pi/netzspeicher/Generic-FlashDisk-01/sensor.py", line 7, in <module>
  File "/home/pi/netzspeicher/Generic-FlashDisk-01/grove_co2_lib.py", line 26, in read
    high_level = struct.unpack('B', self.inp[2])[0]
TypeError: a bytes-like object is required, not 'int'
so it sends data back but not in bytes but in integers, so may anyone can help me with that so i can recive bytes instead of integers?
any help is welcomed
Hi @hugo112,
I think it may be using Python 3. Can you tell us which version are you using? If it’s Python 3, can you give it a shot with Python 2 instead?
hi,
thanks for ur reply, but i got it working in the meantime.
Hi @hugo112,
That’s great. What was that did it for you?
hi,
i just worked through the errors i got till it worked… im new to programing so im a little astonished myself. I can post the code if u like me to.
Hi @hugo112,
Yeah sure, why not. Thanks a lot! :slight_smile:
hi,
sure no problem, here is th new grove_co2_lib:
import serial
# import time
ser = serial.Serial(’/dev/ttyAMA0’, 9600, timeout = 1)
class CO2:
inp = []
cmd_calibrate_sensor = b"\xff\x87\x87\x00\x00\x00\x00\x00\xf2"
def init(self):
ser.flush()
def calibration(self):
ser.write(self.cmd_calibrate_sensor)
cal = “calibration Done”
return[cal]
def read(self):
try:
self.inp = ser.read(9)
high_level = self.inp[2]
low_level = self.inp[3]
temp_co2 = self.inp[4] - 46
conc = high_level * 256 + low_level
return [conc, temp_co2]
except IOError:
return [-1, -1]
# if name == “main”:
# while True:
# print(CO2.read())
# time.sleep(1)
oh, i didnt post the tabs, sorry
Hi…
i used the code and run with python3 & python2 output shows blank screen. any modification in the code?
import serial
import time
ser = serial.Serial('/dev/ttyAMA0', 115200, timeout = 1)
class CO2:
        inp = []
        def init(self):
                ser.flush()
                cal = "calibration Done."
                return[cal]
        def read(self):
                try:
                        print("1")
                        print("2")
                        print("3")
                        print("4")
                        print("5")
                        print("6")
                        print("7")
                except IOError:
                        return [-1, -1]
if "main" == "main":
        C = CO2()
                print(C.read())
                time.sleep(1)
Hi @nagaraju.grandhi7,
There can be a couple of reasons:
  1. You didn’t connect the sensor to the right port. That being the RPISER port of the GrovePi.
  2. You didn’t switch the hardware serial port (/dev/ttyAMA0) to point to the appropriate hardware pins instead of not letting it be used by the Bluetooth - especially important on Pi3/Pi3 B+.
  3. Something is wrong with the code.
As for making sure you’ve got the serial port configured properly, check this page. Everything is described in detail:
