A power supply between 9V and 12V with a rating of 2A is recommended. Will the motors not run with a cellphone 4400 mAh/5V power pack?
Hey Maty,
We haven’t tested this, but the motors will run.
The only problem might be if you’re only supplying 5V, you may see the GoPiGo drop off early: there’s a voltage drop from the power regulator.
