I received my Arduberry from the original Kickstarter campaign but haven’t had much free time to start playing with it until now. After setting up the IDE on my Pi I attempted to upload one of the sample sketches to the Arduberry with no luck, I then went ahead and tried doing the same from my Macbook Pro via the standard Arduino IDE with the same results. I also tried setting up a little LED circuit off the 3.3 volt header on the board but nothing happened, connecting the same circuit to my Pi worked as expected. Am I missing anything or is my board just a lemon? And is it too late for me to get a replacement board or will I just have to buy a new one? Thanks in advance.
Can you run sudo avrdude -c gpio -p m328p on the terminal with the Arduberry on top and post the output here. It’ll help us debug the problem.
this check.
avrdude done. Thank you.
Looks like your Arduberry is indeed broken.
Can you send us a message here: http://www.dexterindustries.com/site/?page_id=65 and we’ll help you out.
